BENEFACTOR
Piper went to those non-rebuild able actuators back in the late 90s. Dumbest thing ever unless you want to sell spare parts. O`rings are cheap.
FABRIC HEADLINER
Folks
As you may remember I did a fabric headliner on my last build and I was happy with it, so I am doing it again. Based on the weight added on the tailfeathers with the covering I am guessing the weight of the headliner is about 1.5 ounces.
First the back panel goes in, then the sides, and last the top. Here are a few photos......I still have to put in the tapes and re-inforcements.
Jay welded in a flat piece across the top for me to attach the fabric to...
And left room around the sides to wrap the fabric...
I put in a little angle brace to attach the fabric to....gets rid of an awkward corner...
I like to use half a wood clothespin to tuck the fabric in the window channel. You need to clean the glue off it pretty regularly, otherwise it will stick to the fabric.
Side going in
You can see where the side comes off the top "C" channel and transitions to my added angle brace
I am not advocating you do this or not. In my case I do not feel like I will be carrying a lot of sharp objects in this area so it is about the lightest way to finish it out. It saves about 4 pounds over a metal headliner, is quieter, and (in my opinion) looks a little better than no headliner at all. The metal headliners are also a little lower so you may lose some headroom for the back-seater.
Hope this helps
Very nice Bill. You do realize that those nut plates can acquire surface rust due to the moisture in the floats. It may be wise to leave the S/S screws in the threads when the floor boards are not installed to prevent rust from accumulating on the threads, making screw insertion and removal difficult. A worst case scenario would require destroying the floorboards in order to remove them if the screws became shall we say stubborn? A dab of anti-seize on the threads might help.
Yep....you guessed it.....more nut plates. Have I told you today how much I like nut plates?
Hope this helps
Folks
In the continuing saga.......Wip issued a Service Bulletin for the pump out tubes and so I am replacing all my pump out tubes in order to bring things up to par.
The original tubes had a flat bottom and I guess it was possible (pretty unlikely but possible) for the tube to suction seal itself to the bottom of the float so that it would not let the water in.
So Wip recommended shaping the bottom of the tube like this, so that it would not suction seal itself up.
The tubing they use (for the 2100's at least) is available from McMaster-Carr. It is part #5181K27 Crack resistant Polyethylene tubing 1/2" ID and 5/8"OD white.
But, as you might be able to see, it needs to be flared to fit the pump out fitting.
I used a piece of dowel rod. I heated the end of the tubing with a heat gun and then while it was soft forced to onto the dowel which expanded it enough to later fit on the pump out shaft. It actually worked out pretty well.
So......another SB complied with.....and the floats are coming together. Next up = putting a floor in the float lockers.
Hope this entertains or helps
You did lather these bolts with a water proof grease prior to installation? I don't see evidence oozing out from under the washers. This helps prevent the bolts from rusting. Then after you are finished you will be painting the bolt heads and nuts with Par-al-keytone? http://www.aircraftspruce.com/catalog/cspages/paralketone.php
It sure is nice to have it all purrrrdy. It won't last but it feels good for a while.
