Wing bottom covering: Aileron pulley cove and aileron cable exits
I chose to cover the bottom of the wing first in order to be able to lay out the inspection rings and get the cable exits right before the wing is enclosed. I’ve been following a checklist based on Steve Pierce’s wing covering checklist and some other sources I’ve found. I’ll attach my final version once I’m done – it’s currently a work in progress.
Javron has a set of pieces available to handle the covering around the lift strut attach points. I ordered these and installed them as shown
Right before covering, I did some pre-work with fabric in this area to cover some of the gaps. I also added a small extension to the cove piece to fill the gap between it and the leading edge. Finally, I pre-covered the area before putting on the wing fabric.
Finally, here is a picture after the wing has been covered. I’ve still got a little clean-up to do, but I’m happy with how it turned out. I may put one overall reinforcing path here – but if I do, I’ll wait until after rib stitching because I believe that tapes will terminate at this point.
I also decided to locate the holes for the aileron cable exits after the first shrink. I think the experienced folks wait until everything is done to do this task but I wanted to make sure it all worked now. I also figured this wasn’t too much of an issue because this is how it works in the Stewart’s video.
Way back when I had put the wings on the plane and rigged the controls, one thing I did was to try to take good notes of where the cable exits were. I compared them to the Piper drawing and they were right on with one exception which I believe is due to the Javron design.
I located where the holes should be and made small holes in the fabric. I then temporarily hung the aileron and used string to check my work (I figured the string is narrower than the cable and I could open the hole for the cable and correct placement issues at the same time).
Once I was comfortable that the holes were in the right location, I routed both cables to the ailerons and created a little more clearance for the cables. I was trying to decide between the traditional leather patches to cover the cable exits and forming tunnels (as is shown in the Stewarts video) and ultimately decided on the traditional patches. The last thing I did was to reinforce the fabric around the holes to lock everything in place for the final shrinking.
I think I can leave the aileron cable tied up to the N-brace from here on in. Once everything is complete, I can fish it through the hole with help from the aileron pulley inspection plate.
