Scott A
FOUNDER
Park City, UT
Oh good.. was wondering the same.Coming soon!!
FABRIC | |||
Hours To Complete Controls | |||
2023 | 2020 | | |
Elevators | 51.0 Hrs | 53.0 Hrs | |
Stabilizers | 47.5 Hrs | 35.0 Hrs | |
Rudder | 30.0 Hrs | 33.5 Hrs | |
Gear Legs | 22.5 Hrs | 35.0 Hrs | |
Hours To Complete Fuselage | |||
2023 | 2021 | | |
Fuselage | 150.0 Hrs | 139 Hrs | |
Hours To Complete Wings | |||
2024 | 2021 | | |
Left Wing | 114.0 Hrs | 151.0 Hrs | |
Right Wing | 153.0 Hrs | 173.0 Hrs | |
Hours To Complete Ailerons | |||
2024 | 2020 | | |
Both Ailerons | 88.0 Hrs | 58.5.0 Hrs | |
Hours To Complete Flaps | |||
2024 | 2020 | | |
Both Flaps | 49.5 Hrs | 63.0 Hrs | |
Total Hours To Complete Aircraft | |||
2024 | 2020 | | |
TOTAL HOURS | 705.5 Hrs | 741.0 Hrs |
Scott, once the decision is made and you make peace with it...You just go back to the ''Fun to build something'' mindset .Oh no! That would be so depressing - glad you pulled through and the result will be great and you will be happy. Dang..making me think more and more about Oratex.
Oli, Thanks!Dan, I hear your pain. Your wife and you make a good team. I'm sure it will look even better the second time.
I might hire you for my next covering job
How did you remove the blue Stewart glue before re-covering?
What are your thoughts about the the AirTech glue compare to the Stewart ?
I did mix products one time with good results: Endura polyurethane top coat over Stewart Ekofill-primer over bare fabric.
Alois,Hello Dan!
My name is Alois Mayr. I am from Austria/Europe.
I have read the construction of your Smith Cub with attention and congratulate you on your wonderful aircraft!
Forgive me, for writing to you like this.
A friend and I, bought 2 Super Cub Kits from Nick Smith in Canada.
Unfortunately we didn't get any usable documents for the approval from Nick Smith.
Maybe you can help us.
The Canadian authority will probably require the same tests and documents for the certification of an experimental aircraft as the EASA in Europe.
We would of course pay for your trouble!
Our authority requires documents such as
Thank‘s a lot!
- "Strength verification for the main structure, wings and fuselage",
- "Rated weights and center of gravity positions",
- "Proof of stability",
- "Proof of flutter safety"
Alois und Jozi
Bearhawk,Dan, I'm interested in your experience using another paint over Stewarts covering. I have two questions
Why do you think your test panel results were different from the final aircraft results?
You say that you sprayed Airtech primer and paint over Stewarts primer. Was this over their Ekoprime or did you go over their Ekofill with Airtech primer?
I don't know much about Airtech primer but it seems there is some incompatibility between it and the Ekofill/Ekoprime. Is it possible the Eko was not fully cured?, that all the water had not left the surface? Otherwise I'm not sure why another product would not stick.
Thanks for the honest write up.
Dan,Alois,
Nice to hear from pilots flying in Europe and buildings Cubs!
In Canada, unless I'm wrong, there are no requirements to provide documents concerning flutter, stability or the strength of a structure such as fuselage / wings etc...Except for the Weigh & Balance calculation. I would guess that for an aircraft to certify as airworthy, a flutter and stability test is carried out in a wind tunnel at max speed and disturbances are introduced to the airflow to see how the structure and controls withstand such vibrations before breaking. Not sure is any of the test were done to the PA-18...Interesthing points that you brought there. My youngest son is an Aeronautical Engineer, I will submit your points to him and see what king of calculations he can come up with. I'll get back to you... Dan
