skywagon8a
MEMBER
SE Mass MA6
A trimming stabilizer is more aerodynamically efficient (less drag at cruise speeds) and enables a greater loaded center of gravity range. The travel range of the trimming stabilizer should be determined by the ability of the elevators to overpower a failure. Balanced elevators increase the surface area giving more elevator authority with less force on the control stick.
Cub Builder's experience is a scary and possible fatal circumstance. A trim tab can have any number of different failure modes with the same result. The only possible trim tab design that I would consider is one with an aerodynamic balance which could float without being connected. Flutter is an experience which you do not want to experiment with. It can happen instantaneously without warning at the most inopportune time. Been there twice (for different causes), "got the T shirt" and I do not wish to be there again.
Do what you wish, but please be very aware of what you are building and what any failure can produce.
