also... I am working/thinking on making simple dies to make that deep seam where sheets/pieces overlap....
ok, I think it will be simple,
I have not tried this yet, but pretty sure it will work good...
this is my original die,
it was made for another purpose,
and is too complicated for what it needs to do,
to make this side of seam, it really does not need those lips on right edge..
that was just part of my old dies
this is the new "simple" add on part to a standard beader die, you already get with a bead roller kit like from harbor freight or williams low buck tools.
you will just one end of it, not the round bead part..
take 2 or 3 5/8" big fender washers from Lowes,
they were in the grade 5 drawers
(its the OUTSIDE size of these we care about, not the 5/8" hole....)
put them on, I am thinking it will take 3 for .060" kydex ( this need to be 2 times the thickness of your kydex plus the thickness of one big washer)
then for the rest of them use big 7/8" washers
you will want to round edges over on these 7/8" ones only,
with a file or on a sander to look kind like the original die
(not done yet in pictures below)
add one here
(actually you can put more here if you want, this is the part that will be twords center of your sheet on back side.. might even be a good idea!)
then
only one to other die
and just bolt that to beader,
might make a bushing or grease bolt and end of die and fill with bondo or epoxy to keep washers centered... or get fancy and weld stack together, maybe drill small holes in washers and rosette weld together....
just wanted something simple any one can make....
would anyone be interested in this as a kit (smoothed, with a bushing to fit bolt)....
what would you be willing to pay??
not saying I want to bother with it, but seeing if there is interest
this seam makes it so nice so you don't catch lip of interior, you roll this fancy seam HOT....
I put this seam in first, with panels made Oversize/length at other lip end.. and fit in plane you determine where to bend lip on other piece to match..
