BC12D-4-85
SPONSOR
Cessna 177RG? Triangular panel in front side windows.
We lost another good pilot and person. Doug will be missed> https://aviation-safety.net/wikibase/281506
It's August and hunting season so be careful.
I read the ntsb report on this crash, and the trim was full nose up. ???
In every picture I find of this airplane, including at a different accident, the stab is set full nose up.
Why is that?
Notice at 5:20 he says at full gross weight the stall speed is over 100. I didn't hear him mention cruise speed, but at full gross there doesn't appear to be much marginNow fill the plane with passengers and fuel then repeat the slow flight-stall series from about 04:00 on. In gusty conditions preferably. I don't know - maybe there's a safety margin in there somewhere.
The report says he was at gross. If he was fighting "violent" winds he was likely flying at or below Va, and when heavy having the trim set for nose up makes sense. As it does for lots of planes post-landing when the pilot doesn't reset it for the next flight. Personally I trim as part of my pre-takeoff routine, not post-landing, so my trim in parking is typically near the nose up limit.
in my 12's, with long mounts, the more weight I add the more the trim moves to nose down for cruise and landing, as all added weight goes to a rearward CG. Empty I land with full nose up trim, at gross I am probably several turns towards nose down on landing. With a gross weight increase and my ELT way back by the tail at full gross my trim is WAY nose down in flight.
Perhaps this could be the cause of some of the other accidents which happened when sightseeing flights ventured into marginal weather in passes? "Oops, I'd better get this beast turned around quickly!"?“The biggest gotcha is that the Otter can stall at nearly cruise speed with a heavy load when the flaps are up and the pilot pulls hard during a steep turn.” He went on: “Then, the torque can roll the airplane inverted.”
I've never had the opportunity to fly an Otter. But this part gives me reservations about letting an inexperienced pilot (I don't just mean low in hours. What type of flying was it?) loose in one.
De Havilland DHC-3 OTTER radial engine Flight Manual> https://www.manualslib.com/manual/1297670/De-Havilland-Dhc-3-Otter.html
It's an interesting read. The local University had one parked at their Auroral rocket test site north of town. They tried to give it away to my employer in the later 1980's. I said if you can move the tail without power then ok. It disappeared and now is quite valuable if intact.
The original link didn't bother my Mac. Here's another> https://guidessimo.com/manual/download/1193214/de-havilland-dhc-3-otter-flight-manual-128.html
Here's the Preliminary Report for N3937M PA-12. See Page 2 for 08/11/2022 Arctic Village Alaska> https://data.ntsb.gov/carol-main-public/query-builder?month=8&year=2022
