Pokette
Chesterfield, Missouri
Here is my flight right after annual:
While in annual one of the problems was the #3 cylinder. I have a total of 131 hours since new. Its compression was low and TCM repaired a bad exhaust valve. I took off from the repair place to travel the 40 miles to my home airport. I flew for about .5 and it was running beautifully. Then at about .7 I heard a loud bang and had a loss of power. Normal play with mixture, make sure primer was caged etc. all to no effect. It would run at about 2400 rpm but was running a little rough. when full power was applied there was the loud banging. At 6 minutes from Sparta i knew it was going to be trouble. I made it back and investigation is underway. Cylinders pressure test OK, #2 is leaking through exhaust but still is at 68/80. The oil was dropped and the filter cut open... it is making metal. Lets how a new aircraft/engine does not need an overhaul at 130 TT!
