dougsappllc
Guys,
I am replacing the wings on my exp PA12. The original builder used J5 wood spar wings, without flaps. I am installing a set of PA12, extended wings with the long flaps, dodge tanks, etc. The existing wings have stock J5 wing and jury struts. Should I replace the entire jury strut assembly on both sides or just change out the rear clamps to accommodate the larger PA12 rear wing strut? also, I am assuming that the front strut is the same as a PA12 strut, is that correct? Thanks in advance for our help.
