Jamesandres
Central Ohio
Got the wings on and rigged. Putting the jury struts on and realize there are options and adjustments to consider. 3 holes shifting for and aft to choose from, adjustment on the top of the front strut.
With out finding any guide we were looking to proceed as follows
Starting with leveled airframe.
Am I missing something? Anyone have a different process they use or advice?
- Bracket on front lift strut plumb under the wing attach point. (keeps the jury strut vertical)
- install front v onto this bracket and adjust top fitting up or down so front lift strut is straight.
- Use one of three holes fore or aft at top fitting to keep the lower horizontal portion of jury strut to rear lift strut height without deflecting rear strut once clamp is installed.
- Remove rear lift strut and slide bracket down to mate with the horizontal portion of the jury strut as the rear lift strut goes back in place.
- Adjust rear clamp so jury horizontal part is parallel to the airstream and no deflection in rear lift strut.
- Install the rear v brace.
