pfjay52
Port Lincoln, South Australia
Ok guys this is my first real post so please be gentle with me! i have a new ( to me) PA-18-150. the battery is slow to spin the motor. i intend to move it forward under the pilot's seat and instal an Odyssey liteweight battery in the near future. as well as move the solenoid , etc. to the same location.
in the meantime i have been investigating the original battery box and wiring. IMHO the whole setup is pretty archaic, and obviously meant for good old lead-acid batteries ( i have a nice Concord sealed unit).
surely all those original connections thru the battery box are a source of voltage drop before the solenoid is even activated. my unit has bare braided flat copper cable which has been soldered at the ends and drilled for each connection.
why not just drill an oversize hole each end of the box , insert a rubber grommet and fit nice sized insulated cable direct from the battery post to the solenoid and ground??
would this mod require an STC or field approval?
also, just above the pilot's head on the right hand side and immediately aft of the Circuit Breaker board, is a plate about 4" square with a 2 pin screw in style plug in the middle and a solenoid ( similar to the starter) behind and connected to it. any ideas ?
thanks for your help , and i look forward to picking your respective brains some more in the future.
cheers,
Phil
cheers,
Phil
