SuperCub MD
Collins, Wisconsin
Good post Cub Special Pilot. As another somewhat unorthadox pilot, what you said makes good sence.
Ground effect should not be feared, but tamed and mastered.
Try this when you get more comfortable Cavy. Find a nice wide runway, preferably grass, and as much cross wind as you feel comfortable with. Do a normal, faster, upwind wing low, crosswind approach to a wheel landing. Stick the upwind wheel on, raise the tail to glue it on, and run the length of the runway holding the downwind main up. Go around and repeat. Reverse landing direction and do it with the other wheel, go around and repeat. And repeat. And repeat..... After you get real comfortable, start doing S turns down the runway on one wheel. Start transitioning the up wind wheel to a slower speed and both mains, and the tail to full stop. Start working with higher crosswind speeds. Repeat, and repeat some more. Try to do this in a low traffic area so that you can get at least 20 to 30 landings per hour.
