Never seen on like that, here’s a picture of the 57 A-model that still had factory cotton on it when it came apart so I’m fairly confident this is the stock set upView attachment 59620
From AR7:The cargo deck is called out in the AR7 TCDS for restricted cargo hauling operations, so I’m looking into options for a legal 2070 pound gross.
This all appears very obvious to me. Do you think Wip would have only gone to 2000# on their STC if they could have made it 2070#?
Which Restricted Category are you planning to operate under? There are several options.
I didn't see where EdH said he wanted to operate in restricted. So carry on.EdH is strictly wanting to haul the most cargo he can get into the plane in restricted as the "litter" was intended. That is what that litter was designed for.
From AR7:
https://www.law.cornell.edu/cfr/text/14/21.25Could you point me to the documentation of other options? Piper report number maybe? I have report 939 dated August 6, 1957, and nowhere in that document is any mention of a Cargo configuration. Those are the instructions for the crop dusting configuration.
I also have Report 762 dated January 17, 1952, revised February 3, 1953 for the PA18A-135, also operating at 2070 Lbs. but that is also specific to crop dusting configuration.
That report is very specific to crop dusting configuration as I suspect drawing 13714 is very specific to cargo configuration. I must operate in Restricted category when flying an external load but I don't think I'm legal to 2070 as AR7 had no such configuration. Or am I wrong?Not the drawing, but perhaps will help:
https://www.univair.com/content/Report-939-Conversion-to-Std-PA18.pdf
That Piper report no. 939 should be the answer. Also keep in mind the FAA will issue dual airworthiness certificates. You can have both a Standard and a Restricted certificate. Then you will not be restricted to only hauling cargo. You chose which to operate under.Yes thanks for posting that. That’s the documentation I was referring to that shows Piper intended the A to be used in a cargo configuration as well as Ag use.
My goal is to clarify the cargo use for A models, and maybe have a way for owners to operate theirs as such. At best it’ll allow a 2070 cargo hauling gross, and at worst, it’ll be a paperwork novelty with good loading information.
When you request the Restricted, I would ask for an exception to 1. Remove cargo floor panel. on page 7. That could be a "gotcha".
Now this question: Would the cargo mod be approved without the additional doubler panels/deck in #1, and only the floor shown in #5? My A-model had the floor in #5 full length from rear baggage to front floor panel near the rear stick. Assumed it was resting on tubing below. The aileron and rudder cable covers were present as was Atlee's stick cover over the rear stick stub. Stock GW only.
Funny thing Gary, this is your old A model. And yes what you described is what was in it up until the recent fuselage rebuild and carbon aluminum floors.
Battery got moved…need to fill in hole…not to spec. Need a spray plane torque tube….hard to find. Owner produced part that doesn’t match original…..who’s going to approve it, your IA? = Ain’t worth the pain.
