Well that may have contributed to the current situation, though metal belly had long since been removed, the little gussets/formers that were attached to the crossover tube had accumulated all the gunk I previously mentioned, the corrosion definitely started externally, now that I examine it closer. Metal belly would have facilitated easier access and preventive maintenance to that area.
Then again, it might not have. This aircraft was flying regularly with all the discrepancies I've noted, many not even listed here.
No use crying over spilled milk in this case, just need to do what's necessary to restore it.
It's been a steep learning curve, owning this aircraft, but other than the occasional sinking feeling in my gut, it has been very rewarding and interesting, delving into it head first. Sometimes feels like a treasure hunt, tracking down the necessary data for old STC's and blueprints.
Also got to know some real artisans that embody true journeymen, with a wealth of knowledge and skills that are pretty scarce nowadays. In a situation like this, my A&P certificate means very little, without that kind of experiential knowhow. Hell, if it paid enough to support my family, I'd apprentice to someone with that skill set in a heartbeat.
Regrettably it doesn't. Not in this State at any rate.
I would love to be able to run a perfect TIG bead and to be able to use an English wheel to make compound curves in sheet metal fabrication and have a proper paint booth setup, and have a machine shop that I can use to fabricate bits and pieces, etc etc.
The crown wheel in the Enstrom helicopter main rotor gearbox used to be cut by hand! You need a 5 axis milling machine to accomplish that nowadays. It astounds me how much knowledge and ability has been relegated to history.
Anyways, I digress... Feeling a little down now.
