3 Piece Boot Cowl - A Handy Design
Darrel Starr
Plymouth, MN
For those of you building or planning to build a Super Cub or similar plane, I would like to recommend building your boot cowl in three pieces. The top piece rolls around the top of the firewall. The two other wrapper pieces slip under the top piece then meet at the bottom in the middle. Dakota Cub builds boot cowls of this general description. Husky boot cowls are in 4 pieces. If you design it to screw together with nut plates on the firewall, you can easily repair it or reach parts hidden underneath.
I really didn't think I would ever take mine apart but after a couple years of use, paint started to bubble around screws. The problem turned out to be a mistake I made when prime painting the parts. I first primed with self etching VariPrime, which is a dark tan, then sprayed over that with white PolyFiber Epoxy primer. I didn't properly prep the surface and the paint separated between primer coats.
It was relatively painless to unscrew the two boot cowl wrappers and the false boot cowl pieces also.
Since I wanted Bob Schefter in Fergus Falls to strip and repaint the parts and since his shop is off airport, having the parts in small pieces rather than flying the SC into Fergus Falls meant that he could use his paint booth and get a nice smooth dirt free surface.
Anyway, just one example of why I'm glad the boot cowl comes apart.
Also, imagine if the rear seat heater box needs repair, not a problem - just take off the right side boot cowl wrapper and have at it.
I second to what Darrel says. I made my boot cowl for my -12 too. Instead of using a 3 piece, I made a 2 piece using a pattern off the old one with posterboard. The top "saddle" piece will make the boot cowl easier to fit because instead of working with 2 big pieces, you are working with 3 smaller pieces. I realized this when I was trying to fit my boot cowl to the frame. If I have to take my boot cowl off the frame like Darrel has had to do, I will have to take my windshield off. For securing the boot cowl to the 3/8 channel, nut plating the channel is the way to go.
Every restorer has a "If I had to do it over again, I would do this different..." list. a 2 piece to 3 piece boot cowl would most likely be on my list.
Darrel, thank you for your contribution! I always take something away of great value with your posts! and great picture to back your explanation... that really helps us technically illiterates. :)
Just had a guy make one like that for my cub.
Darrell, a nylon washer under the screw heads will help keep your paint nice....Husky's have them......I put nylon washers under every screw on new paint on Cessna's, for sure, every one!
No just doing a little repair work. Started out with a craked tailpost. Ended up adding a 3 ft metal belly to the tail and a new boot cowl cause I didnt like the way the other one fit.
Dave, I do use nylon washers under all of the screws -- but the paint lifted anyway, no cure for a bad bond short of stripping it off.
Hi Darrel,
I'm quite new to Supercubs and whilst waiting on a PA18 kit I've ordered, I'd like to buy a pan-box brake to make a 3 piece cowl and some smaller projects whilst building. What width do you think I'll need for the this cowl work? I'm currently looking at a 50" and a 36" unit.
Darrel hasn't been on the site for a number of years, but I've been hampered by a brake / roll that is too small. Get the bigger one unless there's a good reason not to.
a four foot shear is handy - if you have no other uses it for it other than your cub project, it’s probably not worth it...quality tin snips work just fine.
Sheets of aluminum come in 4 foot by 8 foot and 4 foot by 12 foot. Get brake and shear that can handle at least the 48" distances.
I have a Niagara rotary beading tool from about 1900 that I used to do most of my light joggle work, along with the 48" brake and 52" shear I also have a set of 1/4" bead rolls, which add nice stiffeners and edges. I still want to learn to do a wire roll. Good luck, Tim
I have made several firewalls from titanium. Considerably lighter and I did not find it difficult to work with, just different. Drill slow.
See if you can notice the angle of the grind on the drill in the first two pictures. The third picture is comparing the titanium grind on the left with a "conventional" grind on the right.
The flatter grind cuts nicely through titanium. One of my first aviation jobs was drilling holes on the production line for Sikorsky. This flat drill is what we used for drilling the firewall on the top of the S-61 fuselage. I think it was Titanium? It was long ago.
My boot cowl is in pretty good shape. Firewall not so much. I’ll probably order a Ti firewall from Atlee and just have them punch the holes I need.
is the hole in the picture for a defroster?
The fluted edge on the Atlee Dodge titanium firewall in a pain. I fit it on a Super Cub build several years ago.
I didn't like how the boot cowl sheet metal fit around the flutes and cut them off and used a firewall channel from Clyde Smith $85. https://www.cubdoctor.com/stainless-firewalls/index.html He makes a very nice set for reasonable money. Now I order my titanium from Titanium Joes ($200-300) and cut out my own firewalls. I have punches for the holes if you decide to make your own and want to borrow them. Compare to $768 plus shipping on the Atlee Dodge unit. https://fadodge.com/pa-18-titanium-firewall/
I used nut plates in the flange so the boot cowl can be removed in sections and used PRC sealant around the flange, front and back.
Is the difference in weight between Stainless and Titanium really enough to compensate for the difficulty in working the material? What is the weight difference? Assuming the same thickness.
It is considerable but will have to look it up. I don't find it hard to work with. Shears fine, drills fine just slow down the drill and punches fine.
