BENEFACTOR
A friend just built a titanium firewall to replace the stainless firewall on his PA11/AL11 Legend Cub and he saved 3 lbs titanium vs stainless.
Where did that engine mount lug come from Steve? It doesn’t look stock.I used nut plates in the flange so the boot cowl can be removed in sections and used PRC sealant around the flange, front and back.
Thrustline mod.Where did that engine mount lug come from Steve? It doesn’t look stock.
I have used standard aluminum rivets on all the ones I have built so far.Mr. Pierce
What's the proper rivet for the Ti? Monel or is there something else that is less reactive?
I have not made a seal. The Short Wing Piper series have an airworthiness directive to seal the firewall with a non-hardening seal because they used a fiberglass insulation under the floor that would get saturated with fuel and oil and cause a fire hazard. I have not seen any issues. I have removed the side panels to get access to under the panel but usually access from under the instrument panel using a modified creeper that sits on the front and rear seat bases. The top panel can be removed but the windshield would need to come out. I seal around the windshield with a urethane sealant. At the over laps I brake a flange on one side for stiffness.Hi everyone.
For ease of future maintenance when making a 3 piece boot cowl, do you make a ''formed seal'' (I'm not sure of the term that you use?) with heatproof goop like PR812, where the boot cowl is screwed to the firewall's nut plates? Ie: goop one side, petroleum jelly the other and screw them together to form the panel seal?
If you have a avionics maintenance issues, is it easier to make some large removeable panels on top of the dash, or do you remove the windscreen and the top boot cowl panel? I've read that some people use felt to mount the windscreen similar to a Cessna 172, yet others use a caulking compound and I'm not sure if this is a thing that once trimmed and fitted well, you never ever want to remove it again due to the risk of cracking or just being a PITA.
What's the preference for the panel join in the wrapper? A flange / lap seam or a simple overlap with a slight panel edge break?
I'm hoping I can modify the standard parts in my kit when they arrive to suit - they mirror the stock cub setup where the boot cowl wrapper has the fluted formed edge that folds down over the firewall.
Thanks again
Damian
