Darrel Starr
Plymouth, MN
For those of you building or planning to build a Super Cub or similar plane, I would like to recommend building your boot cowl in three pieces. The top piece rolls around the top of the firewall. The two other wrapper pieces slip under the top piece then meet at the bottom in the middle. Dakota Cub builds boot cowls of this general description. Husky boot cowls are in 4 pieces. If you design it to screw together with nut plates on the firewall, you can easily repair it or reach parts hidden underneath.
I really didn't think I would ever take mine apart but after a couple years of use, paint started to bubble around screws. The problem turned out to be a mistake I made when prime painting the parts. I first primed with self etching VariPrime, which is a dark tan, then sprayed over that with white PolyFiber Epoxy primer. I didn't properly prep the surface and the paint separated between primer coats.
![P1160367a.webp P1160367a.webp](https://www.supercub.org/forum/data/attachments/14/14843-fa0cc3b11b5a67ae4ab2a0f6e25f98b6.jpg?hash=GALllprdN3)
It was relatively painless to unscrew the two boot cowl wrappers and the false boot cowl pieces also.
![P1160469.webp P1160469.webp](https://www.supercub.org/forum/data/attachments/14/14855-e9c4c6ca1e9a04719f76afee98de577c.jpg?hash=O3DZLMdYX_)
Since I wanted Bob Schefter in Fergus Falls to strip and repaint the parts and since his shop is off airport, having the parts in small pieces rather than flying the SC into Fergus Falls meant that he could use his paint booth and get a nice smooth dirt free surface.
![P1160811.webp P1160811.webp](https://www.supercub.org/forum/data/attachments/14/14872-68e72a1a91ba24ec336565e6b56e7801.jpg?hash=atsqU7THu0)
Anyway, just one example of why I'm glad the boot cowl comes apart.
Also, imagine if the rear seat heater box needs repair, not a problem - just take off the right side boot cowl wrapper and have at it.
![P1160492.webp P1160492.webp](https://www.supercub.org/forum/data/attachments/14/14887-3046adf353598a419bf68a5aa68fed49.jpg?hash=noVVhz7UuG)
![P1160496.webp P1160496.webp](https://www.supercub.org/forum/data/attachments/14/14896-276f1526ae6f7916b60d347a48c64a12.jpg?hash=THUG0b5uzK)
