Farmboy
MEMBER
Middlebury, VT
So an interesting topic came up today that I thought I’d share, as most of you have a better understanding about it.
The addition of pstol (fowler type) flaps onto an existing taildragger, and perhaps other types, significantly changes the attitude of the aircraft on approach.
To do this, it appears that the aft trailing edge/rear spar/etc is essentially carrying more load, as the resultant lift from the flaps is so much more effective. Is this true?
If so, this doesn’t mean the center of lift has moved aft, but it does seem that the required downforce on the tail will have increased?
So now if you install these flaps on a taildragger that uses a trim tab instead of a trimmable stabilizer, will the tail be less capable to handle or utilize the benefits of the Pstol flaps? Would you think there is a chance of running out of elevator?
Steve, what’s your first hand experience in your cub - can you get to a point of low elevator response, and does the position of the stabilizer change it, other than stick forces?
Inquiring minds...
Pb
Transmitted from my FlightPhone on fingers...
Inquiring minds...
Pb
