BENEFACTOR
Been long distance troubleshooting a Super Cub with a 180 hp Lycoming via the TigerCub former Penn Yan STC. This issue started the summer before last, when the throttle was advanced from low power/ idle the engine would stumble. After checking primer system etc. the carburetor (10-3878) was sent to Marvel Schebler and rebuilt. This winter the engine started doing the same thing. Everything was checked and double checked. Carburetor sent back to Marvel and no change. Talked to Lycoming and nothing was suggested that hadn't already been tried. Was talking to Ken at LyCon about another issue and brought this up. Without me even finishing the story he tells me I probably have a 10-3878 carburetor and I need a 10-4164. Seems when Steve Tubbs was building engines he ran into this issue and carb could be set up to run fine in summer but then have this issue in winter or vice versa. Carburetor is suppose to show up today so it will be interesting to see the outcome. Ken also has a flow sheet on the set up of this carburetor so he can tweak it to flow correctly on his flow bench. Posted this to help anyone else that might have this issue and to see how many others have run into this problem.
