Stew
Haywards Heath, UK
Very many thanks for the above responses.
In the UK many eligible light aircraft types fly under a permit from the UK LAA and that includes all the homebuilds. If it is deemed sensible and safe then you can incorporate changes/modifications following their procedures.
The PA18 is not eligible to go on the UK LAA Permit Scheme so it flies with a full UK CAA airworthiness certificate (as an result, it can be used for training and "hire and reward") . However, changes and modifications are much more time consuming and expensive. I have attached the three modified schematics that I have, I have simply removed the erroneous tags leaving just the swg wire sizes.
As you say, it is not rocket science and a decent scheme could be developed but we would have to go through an approval process or we have to stick to the original with some "minor" mods to incorporate the radio,transponder, electric AH/Turn & Slip, LED landing and nav lights. Sticking to the original apparently requires an original wiring diagram to illustrate how it has been rewired.
Could you just confirm that this is the best schematics/diagrams anyone is aware of.
Kind regards
Stew
Kind regards
Stew
PA18 SuperCub Schematic Wiring Diagram_Serial Nos 7409140 to 7709198_modified.pdf137.4 KB · Views: 171
PA18 Super Cub Schematic Wiring Diagram_Serial Nos 7809001 and up_modified.jpg220.4 KB · Views: 548
PA18 SuperCub Schematic Wiring Diagram_Serial Nos 7409140 to 7709198_modified.jpg211.8 KB · Views: 414
PA18 Super Cub Schematic Wiring Diagram_Serial Nos 7809001 and up_modified.pdf150.1 KB · Views: 177
