First off I'm sorry this is not exactly cub related but this seems to be the best forum for exposure.
I am looking into purchasing a STOL project and had some concerns about one of the modifications to the airframe. Plane in question is a citabria(experimental airworthiness cert), current owner had a 200hp engine in it along with a 150hp shot of nitrous. I will be purchasing without the engine and will most likely go with a more conventional 160hp Lycoming and no nitrous.
Back to the question, on take off he was out of rudder authority because of how much power his motor was making. He stripped the fabric off the fuselage and extended the rear of the fuselage 2ft, this of course moved the rudder back 2ft and in therory would give him more rudder authority. I am concerned about the affects of this at cruise speeds on both the rudder and elevator controls. I feel like this was a sound modification to correct for take off but what will be given up at cruise speeds.
I'm open to hear any input you all may have and can answer any other questions if I did not provide enough input.
