Helmetfire
Caldwell, Texas
I have a Super Cub that had 30-52N Brakes and 40-75D wheels installed. (Cessna 180 wheels/brakes). I removed those and installed the 199-62 wheel/brake kit from ABI which are basically the same thing.
Now for the legal part.... my logs aren't complete for the airframe, but a look on the FAA CD shows a field approval back in '89 for the "inspection of previous installation" of the aforementioned C-180 wheels/brakes. The only catch is, that was prior to being exported to Japan, AND it had a different tail number than it does now. (The serial number is the same)
The FA stamp in block 3 of the 337 reads like this:
The data/alteration herein complied with the applicable (the word Alteration is crossed out)
airworthiness requirements and is approved only for
the above described aircraft subject to conformity
inspection by a person authorized in FAR 43.7
The description in block 8 reads:
Inspected installation of previous installed 8:00x6 tires on Cleveland 600x6 wheels p/n 40-75D with
Cleveland brakes p/n 30-52N. This combination of wheels, tires brakes has been previously approved for
installation on other conventional type aircraft (Cessna 180)
So the question is: Can I install the 199-62 kit as a direct replacement for the C-180 wheels/brakes with a log entry citing previous approval?? Or do I need to buy the $265 Dodge STC for the installation?? I actually already bought the STC, but later found the FA...Airframes will give me my money back for the STC if I don't need it.
Thanks.
Thanks.
