I need some help with the removal of a header tank from a PA12 that has added forward fuel outlets to both tanks. I beleive this is similar to a PA18 headerless system and would like to refernce that if I can find a drawing or other reference.
Randy
Are you sure you need to do anything? It my understanding that only the early 12s had header tanks. Mine dosent have one. Did you put a Dakota fuel valve in with the both position?
looking in parts book it looks optional, not serial number based at all.....just says "if header tank is installed use these plumbing parts..."
and new type 24 gal tanks come with front and rear outlets... and a drawing to hook them all up, without a header which my 12 never had......... YMMV.....
