Marty57
PATRON
Nipomo, Ca
After reading all the opinions on the posts about the Dakota Cub drawings for the headerless system; I have to ask the simple question ........ why remove the header tanks? Is it just for weight savings? Does it provide a better fuel system? The best improvement I can see in a fuel system is adding the front ports. We have two different scenarios here; certified vs Exp. With Certified, you have to follow the STC, so it's really not up for debate. On the Exp side, there seems to be a lot of options. If simple and light is an issue, why not just have front and rear ports on the two wing tanks and feed into one front header tank; avoiding the weight and complexity of running a lot of extra fuel lines around two doors. The use of vented fuel caps with a vent line from one site gauge across to the other takes care of venting issues. What is really gained by eliminating the simplicity of a header tank? Is it just weight? Is it really necessary to have Rt, Left, Both, and Off on the fuel selector? A Cessna 150 has an on and off fuel selector, very simple. It seems front and rear port fuel tank, with a front header system on a Cub with a seaplane door, would allow fuel lines to go more directly to a front header tank, eliminating the long path down the back of the door and than back up front to a selector than gascolator. I get the safety issue but let's remember, a J3 has a fuel tank right above your feet.
I'm not saying a headerless system is a good or bad idea; I'm just trying to better understand the generalities of the two systems when considering a simple, lightweight Cub type build.
Marty57
Marty57
