Darrel Starr
Plymouth, MN
We have an Electronics International SR-8A analyser in our Super Cub. It scans all four EGTs and CHTs. Over the last season, I would watch it scan periodically and got used to the temps I saw and the relationship of one cylinder to another. For instance, #4 is always the hottest CHT and #3 is the hottest EGT. That is #3 WAS the hottest EGT until a few months ago. As the ambient temps got cooler, #2 EGT slowly passed up #3 until more recently #2 has been running 20F higher than #3 instead of 20F cooler. Now none are running particularly hot but still ... Why?
After noticing this, Bob Eckstein performed the annual inspection and compression was up so we ruled out a leaking valve. We switched #2 and #3 probes but that did not reestablish the "normal" EGT relationship between #2 and #3.
My nose cowl still has the original starter hole but with the small B&C starter so it allows quite a bit of air into the lower cowl and there are large air gaps also in the nose around an air box I made that replaces the original oil cooler. So I have been suspicious that the #2 intake tube has been getting a direct shot of cold air (whereas all other cylinders have an exhaust pipe in front of the intake pipe warming the air surrounding the intake pipe). If the intake pipe is too cold, fuel in the air-fuel mixture may not stay vaporized and might liquify out, leaning the mixture when it gets to the cylinder.
I disassembled the #2 intake track and noticed that the inside of the oil sump-to-cylinder tube was coated with a thick layer of fuel dye. That might be normal but I think that is circumstantial evidence that fuel has been condensing in the tube. I installed a new hose section connecting the oil sump to the intake tube and a new gasket at the cylinder but actually the intake seemed to have been sealed properly as originally assembled by Larry Cassem (as one would expect knowing how careful Larry is). I did find that the primer line fittings at the #1 and #2 orifices were only finger tight, that is the only thing I saw that might have allowed some outside air to enter the air-fuel mixture and lead to a leaner than normal mixture.
Also, along the way we installed a cover over the oil cooler because oil temperature was running only in the 160F neighborhood.
Today, Minnesota warmed up to 35F so we took a ride. For the first half hour as oil temp stayed below 160F, the #2 EGT was still running 20F hotter than #3, in the 1260F to 1280F area. BUT then as the oil temp climbed above 180 and stabilized at 185F, the relationship changed. At that point #3 EGT returned to being 20F above #2 as it "should" be. That happened I think because the oil heated the mixture enough so the fuel would stay vaporized in the cold intake tube. So now I am confident that the reason for the apparent leaning of #2 in cooler weather has been the cold #2 intake tube and that I need to protect it from a blast of cold air coming in the lower part of the nose bowl.
Now I know that none of this was serious enough to damage the cylinder and that I never would have known this variation even existed if I had not been watching the SR-8A but still it is gratifying to be able to see an anomoly and to be able to follow a trouble shooting procedure using this fine analysis tool.
Darrel
Darrel
