No clue about the price but I just talked to a LONG time pilot the other day about an AvMap Ultra. Sounds like it is a very basic ADHRS unit. Do some good homework and see if it might work for you.
As far as the current draw on a power source, it's simple math. The 12 volt, 1290 style light, is shown as pulling 2 amps. The Aveo Galactica, as an example LED, pulls .6 amps on a 12 volt system. If you have a left and right nav, plus tail, that's a total of 6 amps vs 1.8 amps. At night, that means quite a bit of extra time when you are in a position to need your lights back on. That extra battery power translates to a number of other systems; keeping the radios available, possible an ignition system, or even an electric landing gear system. Couple that to the inherent crash safety of no heat produced by the LEDs themselves and much smaller wire to power them and it's hard to, NO, it's impossible to explain the lack of movement on the fed's part, to get some of these 'new style' parts blessed off.
