Want to share my experience with broken fuel pump:
A week ago I took off from a grass strip with my 95 SuperCub when the engine quit at about 200 ft. I could land straight ahead - no damage. I suspected vapor lock and let the engine run, which was still idling. Made a full power check to clear the fuel lines and took off again. This time I experienced some power loss, so I climbed away. Cruise was uneventful. In flight I tried different pitch attitudes with full power and realized that the engine failed each time after some time with high pitch on each tank. Nose down and the engine came in again after a few seconds. When I did the deadstick landing I surely pulled back the throttle without thinking about it, otherwise the engine would have recovered with full power again. Suspected fuel supply problems or the carburetor. When I disassembled the fuel pump I found the linkage from the diaphragm to the rod was corroded away, so the pump was dead and I only had gravity feed through the pump! The fuel had to go up to the front of the engine where the pump is sitting and through all the restrictions in the pump and the plumbing. So with high pitch attitudes there was no fuel supply to the carb.
Here is a link to a picture I made of the disassembled fuel pump:
