flyby
Olathe, KS
This is obviously not SuperCub. But it is a Peterson 260SE, is that backcountry enough? Can delete if not appropriate.
Next to the cub, our family hauler is the 182 with an IO470. I value the knowledge on this forum so I thought I'd ask:
Our 182P has an IO470 (Peterson 260 STC). Having a heck of a time keeping it idling.
When cool/cold engine the boost pump has to be on low in order to keep at idle or it will die, like fuel starvation. When engine is warm it will idle fine without the use of low boost. I noticed today after some time warming up, it would idle without boost pump on, however when advancing past 1000 rpms it would then studder, needed boost pump again until it was past 1200 rpm. After the flight and while at full operating temps, I could run at all rpm range without boost pump. It seems this issue is consistently getting worse over time.
Mechanical fuel pump has been rebuilt I believe, but I would have to confirm on the logs. Looking for ideas or direction, last few annuals the mechanics cannot seem to nail down what the issue could be. Adjusted idle mixture etc... At times the fuel pressure gauge will fluctuate in cruise. All are very inconsistent but becoming more frequent.
I am doing a ground run today and will see if I can record some pressure readings on the gauge and report. Any other ideas? One person suggested it could be debris in the mechanical pump relief valve.
