• Folks, some quick guidelines for using the classified section of the forums:
    1. Only supporting members can post ads.
    2. Ads will be deleted for expired members.
    3. Ads will be deleted if not updated in 45 days
    4. Please delete your ad when you have sold your item!
    5. Please choose the proper PREFIX - FS or WTB - when posting.
    WHEN THE ORIGINAL POSTER MAKES A POST WITH THE WORD "SOLD" WITH ASTERISKS ON EITHER SIDE (LIKE THIS "*SOLD*" ) IN IT ANYWHERE, THE CLASSIFIED AD WILL BE REMOVED WITHIN 24 HOURS OR SO
WTB Gas Burning Pre Heater Wanted
Backpacker
PATRON
Dawson Creek, BC, Canada...Mile Zero of the Alaska
Hoping to find an engine pre heater that burns car gas. Looks like they are not made anymore? Think there was one called a Red Dragon.
Mine weighs 55oz. Add a length of steel tubing to reach under the cowling with the torch on the ground and leave a bit of engine cover loose to allow a draft. If there is power I use silicone heating pads and a little buddy car warmer.
The Red Dragon uses propane and 12 volt power to run blower. The Northern Companion uses MSR stove and burns mogas/avgas fine. You can build one yourself pretty easy if you have a stove. Do a search lots of info and pics posted.
1000W Honda generator and electric car interior heater. But seriously a Red Dragon that requires propane and 12V (some don't use the fan) is complicated and propane liquifies at -40F/C. I own one but hope I never have to use it. Anything that creates a flame from fuel can create fires so be careful.
If you can find one of these you'll get all the heat you'll ever need. Just be careful, I burned the generator belt off one of my planes with one. There is a long flexible steel tube which connects to the outlet. It only needs gasoline and a match.
iu
google: military surplus hand crank heater
So that must be what they call a blowpot then eh?
Make your own. Do you have an MSR or similar camp stove? Here’s one made from a bell reducer and duct cap from Home Depot. It shows my Coleman dual fuel stove in it but an MSR stove works, too. I have XGK Expeditions and a Whisperlight. Both have the same heat output. Or search this site for “ammo can heater.” I still have that but never use it. Heating with an open flame requires attending the plane. Not fun. That makes a generator worth the price. Plug it in and go back inside!
Forgive my ignorance here, but could someone enlighten me as to how quickly one of those heaters as stewartb posted would warm an engine from say 0* to say 30-40*F ?? I’m wrestling with the flame vs generator thing, and am curious about the difference. I’m believing that the generator would be slower with just sump pads??
Most of the electric systems use cylinder bands (always get the 100 watt ones) or head probes along with the pan heaters 1 - 1 1/2 hour is usually plenty for the electrical systems. Not much longer for the smaller gas fired if you have cowl blanket and a good system Red Dragon throws out a tremendous amount of heat if you are not careful you will melt stuff. Lycoming says you don't have to preheat until below 10 degrees F. I always carry the gas system in the winter but will use a generator or other power source of possible. DENNY
With combustion heaters it depends on the wind and temperature. Electric heat is applied right to the cylinders and sump. Combustion heaters have to heat the cowl cavity and some of that heat transfers, but you have to heat the accessories, firewall, exhaust, etc first. Definitely less efficient and slower than electric. My Reiff system can have my engine ready to go in 2 hours in below zero weather while I sit inside. If you have a choice? I’ve stood watch with combustion heaters. I’d rather not do it again.
For hangar use or for backcountry use?
If you have an AC outlet to provide the juice, then an electric pre-heater is the way to go - Tanis makes awesome kit that heats from the inside out and much more efficient. That’s not an option if you are camping in the backcountry unless you carry a generator which weighs quite a lot - and then you're carrying two type of fuel (maybe genset converted to propane is the way to go).
An improvised or dedicated combustion heater can be made out of a backpacking stove such as the MSR expedition XGK multi fuel stoves. Mine has a lightweight aluminum snow platform and aluminum wind screens. I use white gas because that’s easy, clean cooking fuel but it will burn leaded a gas in an emergency. A big of scat hose or dryer vent hose would compete the kit.
I’ve never used it for real yet. But it is part of an emergency kit. Requires close supervision IMO.
One of these or similar works well> https://www.amazon.com/Zerostart-2600900-Interior-Electric-Portable/dp/B000NM73ZA Placed in the bottom of the cowl that's covered with a insulated cover plus a propeller cover, it takes maybe an hour from 0* to warm, but that depends on what size engine is being heated.
The advantage of a small generator and electric heater is if you have to camp you got instant heat for you or a shelter plus probably plenty of aircraft fuel for the generator. If the aircraft battery is dead at some point you got 12V charge from the genset. Carry a light cord and bulb and you got light at night or heat from the bulb to keep the engine warm.
If it's windy don't expect a combustion heater to be as effective plus they can get even more dangerous.
Here's a range of preheating options - from catalytic in the cowl to electric heater. (https://fairbanks.craigslist.org/avo/d/fairbanks-wham-engine-heaters/7537811178.html) The ad may not last. I tried them all from plumber's pot, propane weed burner, white gas and propane catalytics, propane red dragon, white gas stoves, coleman gas lanterns, and attached or clamped heaters with hot probes. The small but adequate gasoline generator worked the safest.
If you have your own MSR stove and would like to buy my ammo can? $100.00 and it’s yours. I’m sure the scat hose costs more than that.
I still have a couple of unused Coleman Survival Cats, too. Jury’s out on how good they are.
I have some rigorous experience with propane catalytic heaters...I unintentionally burned a building in Umiat AK. at -50F using one to heat a generator. The unleaded gasoline fed ones work until they quit. All catalytics make water vapor that finds cold and freezes, especially the heater valve to the cockpit interior. They like to coat the inside of windows with ice. And so on.
I've seen a 2" scat duct adapter fastened to the hot air outlet grill on a Honda genset, but not ducted exhaust gas.
Anyone try ducting the Genset exhaust into cowl to double up the heat?
I think you would be throwing a lot of moisture up there with the heat. The best is to fly with a 185 pilot they usually run that 2000 watt Honda, a 50 foot extension cord solves all my problems.:wink::wink:
iu
That thing is awesome.
Hi, check your private messages I will buy it.
thx
I would think the JetBoil butane/propane cannisters and the space/weight savings would trump the gas eating heaters......and you can cook and make coffee with them.
I use the Northern Companion......no issues.........but never tested below zero.
JetBoil doesn't work well in cold weather.
I have used Northern Companion in the minus 30's - works well, just takes longer. The Coleman Dual Fuel stove is easier to handle in cold weather and pretty easy to make a heater with parts from Home Depot. And it will burn 100LL.
PS - the feds don't like butane in passenger airplanes but might be OK Pt. 91.
all in one diesel parking heater on ebay. Pretty tough to beat the hot DRY AND CLEAN air they put out. Great for preheating the plane, warming a trailer or tent and a ton of other handy uses. I have several of them for tents, boats, motorhome and plane.
I have an ammo can heater as well I use out in the field if need be, but I prefer the diesel heater any time I have the generator around or a car battery.
Agreed. Butane/propane liquifies and fails to gasify at very cold temperatures. No gas, no fire. I've used them at -20, but wouldn't trust them any colder.
I’ve used them down to -30F in Willow Ak. Had to keep the battery, regulator and hose caped off and inside where it’s warmish. Cracked the propane bottle to clear moisture before connecting. Kept the 25# bottle and red dragon heater out in the cold.
Per Google: "Propane is more suited to colder environments since it evaporates at -44oF (-42oC) at atmospheric pressure. Butane evaporates at 33oF (0.6 oC) at atmospheric pressure."
Yep, my propane tank in FAI quit delivering propane to my oven at about -44. I stuck a very small stick on silicone heat pad to the side, plugged it in, and it gasified enough to keep the oven working at -58 at least. Just need a tiny bit of heat to gasify. And, as Randy points out, butane is worse.
but not something you want to be doing in the boonies to pre heat. Stick with white gas.
