Longwinglover
Charlotte, NC
Hey group (especially you professional maintenance types)!
I've got a couple of friends who have a 1941 J3. We have discovered that the bushing for the left front wing strut is loose in its' hole in the rear landing gear / lift strut attach fitting (the hole in the fitting is worn).
The airplane was completely rebilt 7 years ago. The bushings were looked at, but NOT replaced at the time of the rebuild :x .
When they originally found this problem about two weeks ago, they thought that the movement was due to the bushing being worn, allowing movement of the bolt. They ordered a new bushing and bolt from Univair, but after tapping out the original bushing, found that the new one easily slipped into the hole with only finger pressure (it should be a press fit). When they temporarily re-attached the strut, the original movement was still evident. That was when we determined that the real problem was that the hole that the bushing was in was slightly worn/elongated. (Don't ask how or when - nobody knows.
The logical fix is to ream the hole round (removing as little material as possible) and to manufacture a new bushing to press into the now slightly oversized hole.
The problem is that the resident (yes, he actually lives at the airport) FAA maintenance inspector has adamently said that can't be done without approved data. (Don't ask how he got wind of the problem.
My request of you guys is: Does anyone have approved data for such a fix? I am making a request to Piper (through the local dealer who doesn't know anything about J3's) but am not holding my breath. Since the J3, J5, PA-11,12,15,17,18,20 and 22 all had a similar wing strug attach arrangement, does anyone know if Piper previously published any guidelines for fixing this problem? Has anyone done a similar fix and do you have a copy of a 337?
Answers from this group will certainly be faster than from Piper.
Thanks in advance for your help.
John Scott
John Scott
