I've flown with VG's quite a bit on a 180 and like them. My question is has anyone put them on a STOL equipped 180 or 182?
That would be great! My friends 180 has a STOL kit but an O470J that's a little anemic. We've been talking about putting VG's on it for a while.I have a friend with a 182 with VG's and an after market leading edge cuff on bush wheels . He really likes the set up ..I can get numbers for you if you like .. RC
The other thing I would be interested in is aileron authority at low speeds. When I flew 185's for a living one of them had a Robertson STOL kit. I really didn't like the fact that at low speeds in gusty conditions you didn't have enough aileron control and had to use rudder to lift a wing. It's always been a pet theory of mine that VG's would fix it.
VG's and the Horton kit are great. Not much a fan for VG's and the Sportsman.
Quickest and easiest improvement to roll control on RSTOL equipped Cessnas is aileron gap seals.
FWIW.
I thought that the aileron gap seals were part of the Robertson kit? The ailerons need wider hinges to move them away from the trailing edge. This is so that they can get the extra down travel. That is why I thought that the seals were part of the kit.
