Rookie
WA
Today while flying my last leg home, I found my trim crank to be non-functional. After an uneventful flight pushing the stick the whole way, I talked to a Super Cub pilot who correctly diagnosed the symptoms as the results of the steel pin that secures the trim crank shaft to the pully assembly having gone missing. I haven't found it yet, but he was right, that's why the crank was spinning freely.
To get the crank off, I had to punch out one roll pin. I then removed the cover plate, and could see that the shaft and the pully are independent. I can see the grooves radially from the shaft hole to allow the installation of the steel pin. I have the pin I removed for the crank, but the drawing I have (from a L-21A erection manual) doesn't show the sizes of the pins. Are they both the same diameter? The drawing makes it look like the one I have is shorter, what is the length of the one I'm missing? What is the best way to get a proper replacement pin?
Thanks!
Thanks!
