Hi, this is my first post on supercub.org and I'm looking forward to becoming a regular contributor
I'm an ex Jodel D112, Pitts S-1S and Andreasson BA4B owner, driver and maintainer and have approximately 60 hours in PA-18 Super Cub.
I've diagnosed a slipping stabiliser trim system to a worn front crank handle pulley, by noticing it slipping when even slight additional pressure is applied by fingertips to the trim cable. I added some friction tape to the pulley which immediately cured the problem and then ordered the replacement pulley from Univair.
I've added external access to the back of the pulley crank by a new inspection hole and slackened off the trim tension as much as I dare, by adjusting the rear horizontal tension adjusting bolt to the end of its travel
I've looked at the 4 existing threads on this topic which have been useful, but I still have 2 removal/replacement questions please:
I can see the locking pin in the (fiber) pulley as in the attached photograph. The pin doesn't SEEM to be ended, but gently tapping with a hammer and drift from the less exposed pin end produced no movement. From looking at the photograph last night, MAYBE the easier "ramp" in the pulley groove is at the least exposed end and maybe I should tap from the other, more exposed pin end? Is it necessary to "help" the pin coming out by further grinding the pin ramp? Is there a better way to remove than tapping? In short, what is the best way to get the pin out of a fiber pulley
I suspect I may need to reduce cable tension further as part of the pulley replacement and am trying to decide which of the very tricky options is easiest/most recommended:
Completely take the adjusting nut off the horizontal rear tension adjuster and then swear lots in trying to get it back on again
Take off the split pin and castellated nut from the tensioning pulley axle, take out the axle and pulley and then swear lots in trying to put them back in again
Take off the split pin and castellated nut from the pivot arm of the horizontal rear tension adjuster and then swear lots in trying to get it back on again
OR!!!! Is there an easier way?!!!!!
Thank you!!
Philly
Thank you!!
Philly
