Steve's Gascolator
I have never had an issue with the cotter pin. Even new the original POS gascolator is a thorn in my side. Safety wired and bent the pigtail and the POS started leaking. :evil:
A mechanic buddy of mine just got through installing a Steve's gascolator on a Champ,
I was talking about the PITA of replacing the cotter key and he suggested some long offset hemostats.
This is what I use for the hard to reach ones...
A good percentage of the installations are easy to get too though... Cessna 180, early 182 and 206 are the main ones off the top of my head that are a little harder to do..
Brian
I just purchased a SA gascolator to replace the original on my PA-12 rebuild.
I have seen some installing a stand-off to space the original bracket away from the firewall to give room for the fuel line to come thru the firewall and connect to the gascolator.
Pros/Cons to this? I think it would allow for a more sealed/cleaner firewall and easier to preflight that connection.
Also, is 3/8” aluminum standard for the fuel line from the selector to the gascolator or should it best be a flexible line? This airplane has the Cub Crafter fuel selector STC.
Those might be great for a Cub installation,
but for a C180 installation IMHO not so much.
Too hard to reach up in there & monkey with it.
I bought a pair of medical hemostats specifically for reaching up & removing
& especially reinstalling the cotter pin in my Steves gascolator.
Maybe not according to Hoyle but I leave it unbent,
it's not about to migrate upward & come out unless I was to pull some sustained negative-g flight.
In turbulence.
