The J-3 has some play in the right front lift strut between the lower fork and the fuselage bracket. I've not looked at it myself yet, but suspect one of the following, a worn fork, a worn bolt, or elongation of the hole in the fuselage bracket (probably the latter, or a combination of the last two). What is the standard 'fix' for this? Needless to say, the plane's on the ground till we get this sorted out....
The likely fix seems to me to be reaming the elongated hole out and installing a larger bolt and fork, but I just said considerably more than I know. All advice welcome -- short of swapping the -3 for an -18
