It wasn't easy but I got one off today. Maybe the next will be easier.
Try 2 2x4's 16" long or so, laid flat and parallel just clear of the hub, then another shorter board on top of the first two, centered and at a right angle to the others. Jack/push/press on that, thus applying the needed pressure more around the entire rim. Since I got the retract skis I go through this every winter, I use the system described and my crane outrigger pad to provide the push. I look forward to doing it now, dreaded it before. If you don't have a crane your lever arm setup is the way to do it. As strong a fulcrum and as long/strong a lever as needed. If I was doing it by hand I'd rig something using my post and beam outbuilding post as the fulcrum and a 8 or 10' board, or two, yours looks a little short coupled but if it works, great.
