Speedo
FOUNDER
TN
I need some diagnostic help: I run an O-320 B3B (160hp) in my PA-12. The engine is approximately 600 SFOH. For roughly the first 550 hours the maximum achievable RPM in a 60 mph climb out was around 2450. Recently, though, I have been seeing 2700 RPM in a 60 mph climb out. This suggests to me the following possibilities: a) I have a miracle engine that gets stronger with time, b) I have a miracle prop that loses pitch with time, c) the plane's tach is wrong, d) the throttle formerly could not travel its full range, but now can, e) there was some other constriction in the fuel flow which has somehow corrected itself, or f) none of the above. If you know a diagnostic test I could perform to ascertain what has caused this change, please pass it along.
FYI, I have checked the plane's tach against an optical tach, and have found the plane's tach reads 50 rpm high at 2500 rpm.
Also, I have not changed anything about the engine or the prop.
