irishfield
Not going to get in a piss and moan over it Aaron, as neither of us need the BP raise. Thought I was just offering advise to save the Experimental guys some fuel money! All I can tell you is that I haven't burnt out a used $1.49 flasher unit (or bulb) in 8 years (600 flight hours) and I'm lighting two 100W halagon driving lights with every pulse. I would also suggest that is what the capacitor is for inside the relay housing...to absorb the "spark" (at least that is what I remember being taught when I was getting my Electro-Mechanical Eng degree), but yes these days you are more liable to buy an electronic flasher in an auto jobber as they can sell them for more and are cheaper to mfg than an "old Fashion" wire wound relay.Rookie said:If you really think a cheap relay is equivalent to solid state electronics with appropriate cooling, then go ahead and build your circuit.
However, I'll remind you that the typical aircraft bulbs are drawing a lot more current then the turn signal in an automobile (and that most modern automobiles now use electronics not relays), and if you could see what is going on inside that relay, you'd see a nice hot spark arcing across those relay contacts each time they open and close. That spark quickly burns up the contacts, which typically aren't design for that kind of load.
You get what you pay for. My $0.02.
-->Aaron
Another option for the Experimentals would be to find the source for the police car wig wag lights, although being government they are probably paying twice or more what the Pulselight system costs!
Cheers,
Wayne
