Helmetfire
Caldwell, Texas
Why does my oil pressure indication fluctuate proportionally to engine RPM??
I always thought this was normal, but somebody mentioned that this should not be the case and the oil pressure should be consistent in terms of RPM and only decrease slightly as the oil temperature increases.
My oil pressure indicated around 55 psi on startup and would indicate around 65-70 psi at cruise rpm. Checked the pressure regulator and noticed it had 3 washers installed. We added another 3 washers and the pressure indicated about 10 psi more than before, but still varied proportionally to rpm. Either way, pressures would decrease slightly with higher oil temps which has always been the case. When we checked the regulator, the mech said the ball looked "worn", but hard to say if it was causing any problems, so we re-installed it with a few more washers to see what happened.
Hoping this has something to do with the pressure regulator, and not deeper in the engine as we just finished putting 4 new cylinders on. :-?
Any ideas?
Any ideas?
