JWE
NC30
Shortly after we bought our aircraft the main 50 am circuit breaker started popping. 60 amp alternator with an external voltage regulator. We thought maybe the CB was bad so replaced it. Several flights with no issues then the CB popped again. We installed a CGR 30. Voltage read rock steady at 14.4, but amps were jumping erratically no matter what the electrical load. I/A checked and tightened several electrical connectors and the erratic amperage fluctuations reduced a bit but continued. CB continued to pop. Took it back to I/A last week. He checked the OHMs on the alternator and said they were out of tolerance. He replaced the alternator. We picked the airplane up yesterday from the shop and have only flown about 45 minutes since. The CB hasn't popped (yet - fingers crossed), but the amps continue to fluctuate although not nearly as much. With the new alternator the voltage reads steady at 14.2. It's my understanding he hooked the CGR 30 up so that the readings are from the alternator, not the battery. When the weather permits we'll fly some more and see if the CB pops again. In the meantime, any suggestions?
