I had similar symptoms with my engine at 1,100 hours. Long story short, the first ring on the forward, right cyclinder fell out in 7 pieces, cam was hosed, oil pump gears and housing badly scored. One word of caution for the re-build, the repair manual instructs the mechanic to place the gasket for a prop governor under the blind plate on the high pressure oil port on the back of the engine. There is a tiny footnote that can go unnoticed which says to substitute a solid gasket under the blind plate if you don't have a prop governor. Don't make the mistake of using the weaker gasket under the blind plate. Mine blew out at about 10 hours after the rebuild dumping 8 quarts of oil in about a minute. Fortunately, I was at 13,000 feet when it blew out and I was able to dead-stick 18 miles to a gravel strip. If you don't like flights that finish with dead-sticking, make sure you get the correct gasket there. Send me a message if you want more details.
