oliveros
Cali, Colombia
I made the front floorboard according to Northland CD blueprints ( NL 10737-12.pdf ) the problem began when we were installing the floorboard channel reinforcement, NOTHING fit well, then I realized that the beautiful floorboard I made with all my effort was not the correct one. Then I started searching and find the one in supercubprojet (for the L21) This one was not exactly the one, but fit better 10737-2 is the blueprint I used then.
The floorboard channel fit well, but the center pulley hole was not exactly in the correct position.
Finally I finished the floorboard, I modified on the run to match the plane not following the blueprint exactly.
Although it worked, I want to know if there is any other floorboard design out there?
My current floor board
This is the Northland one
