KindaSuper
Fatboy Cub
Meet the team,
Eric Lewis (lewaero works). Eric has built several planes that are recognizable such as the twin cub or double ender, and the Ascender. Lewaero works also makes carbon fiber pods for carbon cubs both fuel and cargo versions. Cubcrafter buys our pods when a customer orders one through them.
Chris Reese is a CFI that is passionate about aviation and wants people to be better pilots. He is currently a pilot for Ericson in the Casa 212 moving cargo or parajumpers. He is also a CFI and tailwheel instructor when he is not flying for Ericson.
Josh Peterson is a CFI and tailwheel instructor that wants to keep stick and rudder flying alive in the upcoming generations of pilots. Josh is new to aviation building but has a lot of experience building race trucks. He is a shop aid for Lewaero works when he is not instructing.
The premise behind Fatboy
When looking for planes that can fit bigger and taller guys we really didn’t have an option in the cub market. That is when we set out to make something that will have all the cub performance but be able to fit a 6’6” pilot with a helmet. The design is based on a cub but several modifications are made to make it fit our mission. The fuselege is hand built in the shop extended 18.25” widened 4” and the roof was raised 2” and was design with Alaska flying in mind. All super cub Alaska mods taken into account while designing the fuselage and are built in.
Some spec for Fatboy
· Engine O-360-C2P 180hp
· Prop Still researching
· 3” extended Gear 1.5” axles
· 35” Bushwheels
· Baby bush tailwheel
· Acme Shocks
· Custom Carbon floor boards
· Custom Seats
· Single Controls
· Massive cargo door
· Angle of incidence change
· Javeron wing kit
· keller flaps 50/50 split with ailerons
· Custom carbon fiber leading edge droop cuff
· Gross weight will be 2300lbs
Fatboy designin software
Window start
Longerons Start
Starting to Square the fuselage
We widened the foot well for more leg room
Our custom cargo door that fits a 85qt cooler in no problem!
We made a landing gear fixture to make sure we are square
Here is the view from the back with a tailwheel mounted
Gear test fit nice and strait and parallel with each other
Wing test fit and strut length sizing
Back view with some shop tail surfaces and wings mounted
Sit test with Josh in it he is 6'6" 260 on a stock cub seat.
Floor prototype 300lbs test and only weighs 8oz per sqft
Here is one of our fuel pods that we make in house.
Meet the team,
· 35” Bushwheels
· Acme Shocks
· Custom Seats
· Single Controls
· Javeron wing kit
Window start
Longerons Start
