frequent_flyer
Arizona, USA
Still concerned if wot and fuel pump failed.
You have 2 fuel pumps don't you. As I said earlier the engine will stop if neither is working. A carb will work on 0.5 psi or less but the injection servo needs at least 20 psi.
If you are concerned about the engine driven pump you should run a test of its delivery. I don't know a standard way to do that but, unless I could find one, I'd pull the top plugs and crank the engine with the starter with fuel line disconnected at the fuel servo.
