I don’t have a dog in this race, and so this may just muddy the waters.
The one time I was able to speak to Craig Catto directly because Nicole wasn’t in the office to stop it, I learned a few things.
~ Catto builds different props in the same size, and so unless you call them with the serial numbers of different props, comparing two props of the same size and pitch can mislead you. Same diameter, same pitch, different chord/blade design, but labeled the same.
~ Props labeled as one thing can be slightly different. I pulled a 7638 off a plane to test on mine, and inside the hub was the signature of a fellow at Catto, signing off the prop as a 7637.
Props have a lot of black art in their designs, so I believe the only truths are directly from the guy that makes it, and/or your exact results of the specific prop mounted on your specific engine mounted in your specific airframe.
