Cargo pod tab locations
DJ
MEMBER
Bolivia
Anyone have measurements for rear pod strap locations? I want to add tabs now before paint.
How far aft of the rear gear fitting for the common pods like Airglass 32 gal or Firman cargo pod? How beefy should the tabs be? Wrapped around the longeron?
39 inches aft of the rear edge of the lift strut attachment bracket for Airglass.
Firman/ Alaska bush pod all cargo.
Zero’d the level on the D window forward frame, and they are angled in 25 degrees
Thanks all. I stuck them on the inboard sides of the longeron since this frame is really wide. 20221013_171726.jpeg20221013_171805.jpeg20221013_161821.jpeg
Keep in mind you will have to get custom pod straps or put extensions on regular straps you may get with a pod. Anywhere in the 38.5-40" range is fine. It should be just ahead of the cluster as you did there.
Thanks. I'll have to extend the straps I have. I'll need the pod for fuel occasionally otherwise I probably wouldn't bother on the 4 place.
