Staff member
Northwest Arkansas
I have been in three carbon cubs. The first I "rode" in, the second I flew with my wife in the back on a very hot day and full fuel, and while in Winifred, Ralph Rogers let me fly his wife Melissa's Carbon Cub (after blackmail threats, chicanery, etc) with 1/4 tanks all on my lonesome.
Winifred is about 3300' elevation and I would say the density altitude when I flew was about break even with the actual altitude, maybe a few extra hundred feet high. We had been watching a Weatherly take off with a spray load that was using up nearly all 4000+ feet of runway.
If I had to sum up the 20 minutes or so I spent in the plane fooling around, it would be to say, "There is a reason this plane is so popular". This is truly a fun flying airplane and in spite of my efforts to make it misbehave with cross controlled stalling, etc, I was given only a gentle response. I virtually ignored the glass stuff on the panel and just looked out the window. I occasionally looked at the steam ASI out of curiosity and at the GPS groundspeed when slow flighting into a headwind, but otherwise, just flew it by feel. To use Ralph's words, flying this plane is, "Almost like cheating" it is so capable, yet so docile.
I had been practicing spot maximum performance (for me) landings in the C180 when I came in and was consistently turning things around in under 400' (remember, density altitude more than 4000' most of the time) but I was using a lot of brakes, and really working at it. by contrast, I literally "plopped" the Carbon Cub in without much thought in less distance with no brakes. If you have flown a cub - other than the flap location and electric trim - you will be right at home. The overhead flap location and the electric trim are easy to get used to, and not unlike a regular supercub, trim is a set it and forget it item.
I did quite a bit of slow flight and stalls - the power-off ones were really "mushes" rather than stalls, and cross controlled while doing so - and found them quite docile.
To reiterate, it's fun, easy, and I can see why this is one of the hottest little planes on the market right now. Frankly, it's not in my budget at the moment and may never be, but I look forward to the next time someone throws me the keys!
