One of my generator bolt heads sheared off. Learning that this is common.....would a stainless grade bolt be better than the legal aviation grade bolt? Why do these bolts fail? Also I am installing some safety cable I recieved from a friend. What part number do you use when ordering the longer bolts needed for the cables. How do you tell if the cables are long enough. I held them up on my cub and they do not seem to have the slack that I see in most of the picture. Anyone have a measurement on the amount of slack you should have? Thanks again, Mark
