I attempted to install a new light weight Plane Power alternator from Aircraft Spruce today. My O-320 powered PA-12 has the front mounted oil cooler.
The problem is the new alternator mounting bracket will not work with the oil cooler mounting bracket arrangement. Before anybody says this would be the perfect time to get the rear mounted oil cooler, I bit the BIG $$ bullet and got a new front aluminum cooler from Niagara!
Are there any options to use this alternator other than cutting and welding up a new alternator/oil cooler mounting attachment? I really don't want to do that. Are there any parts I can order to do the installation or is there another light weight alternator option?
Thanks for the help.
David
David
