16-bravo said:I think that what they need to build for us guys that are torn, is a lightwieght 33" bushwweel, that will fit on our 6" wheels. I think I would definitely buy a set of those, no matter what my wife said. ABW, can you help us guys out that can't make a decision. PLEESEEEEEEE.
Ak said:Didn't the old 35 inch Goodyear air wheels run a 6 inch wheel. Why can't the 35 Bushwheels be designed with a 6 inch wheel in mind?
Ok here ya go...
BUY THE 35's
16-bravo said:Ok here ya go...
BUY THE 35's
OK, OK you talked me into it................ as soon as I get my government bailout check. :lol: :lol:
I think that what they need to build for us guys that are torn, is a lightweight 33" bushwheel, that will fit on our 6" wheels. I think I would definitely buy a set of those, no matter what my wife said. ABW, can you help us guys out that can't make a decision. PLEESEEEEEEE.
Easy to explain....Larger diameter down low = more drag. More drag down low = more nose up trim required. More nose up trim = more drag. Full nose up trim + more drag down low = less up elevator effectiveness/authority. Less up elevator authority = higher stall speed, if it actually stalls. The available up elevator force is not strong enough to pitch the nose high enough to achieve the wing's stall angle of attack. Thus a higher indicated stall/mush speed... I needed more nose up trim on climb out. .. I lost 2-3 mph at 2400 rpm... I went up to do some stalls and my usual full nose up trim/full flaps/1600 RPM of 42 MPH was not working (I could not trim all the way back). Same for Base/final turns felt kind of wonky. It could be just me.
Do you really land in areas which need that large of a tire? Must be some really rough stuff.
If you really need/want the big tires, adjust your loading schedule to move the CG aft. Moving the CG aft will require less nose up trim, somewhat counteracting the extra trim drag from the tires.
With typical suspension 8# is too much air. For soft or uneven surfaces try 4# and adjust from there. Rolling over soft ground will be easier (less taxi power) and smoother. 35s can soak up big hits with low air pressure. Add gas shocks and you may like running tires a bit harder and suspension softer so you don’t give up the cushion.
