And when a PA18 is flat-ish like a 12 they are fast, well for a cub anyway...
Think of this aviation 101 diagram.All else being equal, when you change the angle of incidence of the wing, you are really changing the angle which the fuselage flies through the air. Thus the question should be "What effect will changing the angle of the fuselage 1 or 2 degrees have on the overall drag of the entire airplane?". Will the fuselage generate more or less drag when the angle is changed?
Think of this aviation 101 diagram. All else being equal, when you change the angle of incidence of the wing, you are really changing the angle which the fuselage flies through the air. Thus the question should be "What effect will changing the angle of the fuselage 1 or 2 degrees have on the overall drag of the entire airplane?". Will the fuselage generate more or less drag when the angle is changed?
Has anyone investigated whether reflexing the flaps, in effect reducing the angle of incidence, reduces drag at cruise? I surmise that in cruise, angle of incidence controls fuselage angle more than thrustline.
Let's see if this helps to answer the question. The wing has a normal nose down pitching moment. The horizontal tail is positioned to offset that moment keeping the pitch attitude stable.What I was asking was the engine mount thrustline degree change,not the wing. If the engine thrustline was up a degree or two from neutral, what would the effect be? Slower cruise, or?
I tried this with my 185. I can change the angle of the ailerons electrically in flight. I tried various drooping and raising positions along with neutral. Neutral was the fastest, all other positions slowed the speed.Has anyone investigated whether reflexing the flaps, in effect reducing the angle of incidence, reduces drag at cruise? I surmise that in cruise, angle of incidence controls fuselage angle more than thrustline.
Mark, let me ask something about your trustline on PA-18. Everybody talk about visibility issue. Reading about Stolquest SQ2, its engine's mount is lowered 3" and zero-degree trust-line but it engine cowl is very different.
My question is. Could we, in a new engine instalation, using the original top cowl, to lower the engine mount with your trustiline mod enough to keep the visibility as it is in original PA-18?
Best Regards
AC Muller
Best Regards
AC Muller
Steve thanks for the detailed report on Thrustline. In the last photo, it appears that the oil cooler sits a little higher relative to the nose bowl opening: Did you notice any effect on cooling? And which flavor oil cooler are you running? Also notice no gap seals between nose cowl and oil cooler. Hope this doesn't lead to thread drift [please separate threads if appropriate], but there are sometimes unanticipated effect from good mods like this. I'd be interested to hear others experience with this as well, including Mark's.
Thanks. cubscout
Thanks for the very detailed description of your before and after and not just telling me to look elsewhere. The kind of response i was looking for.I had done searches and have read all 18 pages of this particular thread. As with most, alot of drift from topic but entertaining none the less. The comments that come closest to what i had in mind were a few about stacking washers under the mount on a PA-11.But your right, i really asked the wrong question. should have been,I merged the Thrustline Modification threads together. Hope you have some spare time, 18 pages of posts. Very good information. I will comment on my experience shortly.
